If [Consider Paper Type] is set to 'On'
If [Consider Paper Type] is set to 'Off'
Automatic Paper Selection*1
Thin, Plain 1, Plain 2, Recycled, Custom*2
Thin, Plain 1, Plain 2, Recycled, Color, Heavy 1, Heavy 2, Custom*3
Auto Drawer Switching
If there is a paper source with the same paper size, type, and color, the machine automatically feeds from that paper source and continues printing.
If there is a paper source with the same paper size and the paper type can be used with Automatic Paper Selection, the machine automatically feeds from that paper source and continues printing.
If the paper type is specified*4
All paper types available on the machine are eligible for use with Automatic Paper Selection if they match the paper types specified on the printer driver.
Auto Drawer Switching*5
Thin, Plain, Recycled, Color, Heavy 1, Heavy 2, Custom*3
Auto Drawer Switching*6
Thin, Plain 1, Plain 2, Recycled, Color, Custom*7
If there is a paper source with the same paper type and color, the machine automatically feeds from that paper source and continues printing.
(Settings/Registration).
At least one of the paper sources besides the multi-purpose tray must be set to 'On'.
The settings under [Copy] include an option called [Consider Paper Type], which determines whether the machine considers the paper type loaded in a paper source.
If you set [Consider Paper Type] to 'On', paper is not fed from another paper source when the original paper source runs out of paper, unless another paper source is loaded with paper of the same size and type. For more information on stored paper types, see "Registering/Editing Custom Paper Types."
If you set [Consider Paper Type] to 'Off', paper is fed from another paper source when paper in the current paper source runs out, as long as the same paper size is loaded in that paper source.
