Options Attached
Default Setting
Tray A/B/C
Inner 2 Way Tray-H1
Tray A: Copy, Access Stored Files
Tray B: Printer, Receive, Fax, Other
Inner Finisher-D1 and Inner Finisher Additional Tray-A1
Staple Finisher-G1 and Buffer Pass Unit-H1
Tray B: Printer
Tray C: Receive, Fax, Other
Booklet Finisher-G1 and Buffer Pass Unit-H1
Tray B: Printer
(Settings/Registration).|
Details of each item are shown below:
[Tray A]:
Tray A moves closer to the output area.
[Tray B]:
Tray B moves closer to the output area.
[Off]:
The tray home position is not set. The output tray stops at the position it is in when printing finishes.
If a certain tray reaches its stacking limit, the machine automatically uses another tray that is designated for the same function. However, it is recommended that you only designate one tray for fax/I-fax documents to prevent them from getting lost.
You can designate an output tray for multiple functions.
The priority order of the output destinations is determined by the order of the selected output trays. The priority is displayed as "1," "2," and "3."
