Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Paper Feed Settings]
[Paper Drawer Auto Selection On/Off]
Copy, Printer, Access Stored Files, Receive/Fax*1, Other
Yes
No
MP Tray: On, Off
Off
Yes
No
Other: On, Off
On
Yes
No
Copy: Consider Paper Type: On, Off
On
Yes
No
[Feed Method Switch]
MP Tray and Other: Speed Priority, Print Side Priority
Speed Priority
Yes
No
[Suspended Job Timeout]
On, Off
Off
Yes
Yes
0 to 999 mins
5 mins
Yes
Yes
[Paper Output Settings]
[Output Tray Settings]*1
Tray A: Copy, Access Stored Files, Printer, Receive, Fax*1, Other
Tray B: Copy, Access Stored Files, Printer, Receive, Fax*1, Other
Tray C: Copy, Access Stored Files, Printer, Receive, Fax*1, Other
Tray Home Position: Tray A, Tray B, Off
If the Inner 2 Way Tray-H1, or Inner Finisher-D1 and Inner Finisher Additional Tray-A1 Are Attached:
Tray B: Printer, Receive, Fax, Other
If the Staple Finisher-G1, or Booklet Finisher-G1 and Buffer Pass Unit-H1 Are Attached:
Tray B: Printer
Tray C: Receive, Fax, Other
Yes
No*2
[Offset Jobs]*1
On, Off
On
Yes
Yes
[Job Separator Between Jobs]
On, Off
Off
Yes
Yes
Change (Select Paper Source)
Yes
Yes
[Job Separator Between Copies]
On, Off
Off
Yes
No
Copies (1 to 9999)
10
Yes
No
Yes
No
[Different Paper Sizes for Output Tray]*1
On, Off
On
Yes
No
[Print Settings]
[Print Priority]
Copy: 1, 2, 3
1
Yes
Yes
Printer: 1, 2, 3
2
Yes
Yes
Access Strd File, Receive/Fax*1, Other: 1, 2, 3
3
Yes
Yes
[Local Print Default Settings]
Select Paper: Auto, Select Paper Source
Auto
Yes
No
No. of Prints: 1 to 9999
1
Yes
No
Finishing*1:
If No Finisher Is Attached and Only the Inner 2 Way Tray-H1 Is Attached: No Settings, Collate (Page Order), Group (Same Pages), Rotate 90 Degrees
If the Inner Finisher-D1 is attached: No Settings, Collate (Page Order), Group (Same Pages), Staple (Corner (Top Left, Bottom Left, Top Right, Bottom Right), Double (Left, Right)), Offset
If the Inner Finisher-D1 and Inner Puncher Are Attached: No Settings, Collate (Page Order), Group (Same Pages), Staple (Corner (Top Left, Bottom Left, Top Right, Bottom Right), Double (Left, Right)), Offset, Hole Punch
If the Staple Finisher-G1and Buffer Pass Unit-H1 Are Attached: No Settings, Collate (Page Order), Group (Same Pages), Staple (Corner (Top Left, Bottom Left, Top Right, Bottom Right), Double (Left, Right)), Offset
If the Staple Finisher-G1, Buffer Pass Unit-H1, and External puncher Are Attached: No Settings, Collate (Page Order), Group (Same Pages), Staple (Corner (Top Left, Bottom Left, Top Right, Bottom Right), Double (Left, Right)), Offset, Hole Punch
If the Booklet Finisher-G1and Buffer Pass Unit-H1 Are Attached: No Settings, Collate (Page Order), Group (Same Pages), Staple (Corner (Top Left, Bottom Left, Top Right, Bottom Right), Double (Left, Right)), Offset, Saddle Fold, Adjust Fold Position
If the Booklet Finisher-G1, Buffer Pass Unit-H1, and External puncher Are Attached: No Settings, Collate (Page Order), Group (Same Pages), Staple (Corner (Top Left, Bottom Left, Top Right, Bottom Right), Double (Left, Right)), Offset, Hole Punch, Saddle Fold, Adjust Fold Position
Collate + Other
Yes
No
2-Sided Printing: On, Off
Off
Yes
No
On: Book Type, Calendar Type
Book Type
Yes
No
Delete File After Printing: On, Off
Off
Yes
No
Merge Files and Print: On, Off
Off
Yes
No
[Output Report Default Settings]
Off
Yes
Yes
[Register Form]
Register (Solid/Transparent), Delete, Check Print, Details
Yes
Yes
[Register Characters for Page No./Watermark]
Register, Edit, Delete
Yes
Yes
[Copy Set Numbering Option Settings]
On, Off
Off
Yes
Yes
Select Option
ID/User Name: On, Off
Date: On, Off
Text: On, Off
Off
Yes
Yes
Copy Set Numbering Option Settings: Date Settings (mm/dd/yyyy, yyyy/mm/dd, dd/mm/yyyy, yyyy.mm.dd, mm.dd.yyyy, dd.mm.yyyy)
mm/dd/yyyy
Yes
Yes
Set Characters
Yes
Yes
Alignment Settings (Align Left, Align Center, Align Right)
Align Left
Yes
Yes
[Secure Watermark/Document Scan Lock]*1
[Forced Secure Watermark/Doc. Scan Lock]
Copy, Access Stored Files, Printer: Do Not Set, Force Secure Watermark, Forced Doc. Scan Lock
Do Not Set
Yes
Yes*3
[Printer Driver Watermark/Doc. Scan Lock]
Do Not Set, Driver Secure Watermark, Driver Doc. Scan Lock
Do Not Set
Yes
Yes*3
[Adjust Background/Character Contrast]
Relative Contrast (-7 to +7)
(imageRUNNER ADVANCE 4051/4045/4035)
0
No
No
(imageRUNNER ADVANCE 4025)
1
No
No
Standard Value Set. (1 to 64)
12
No
No
8
No
No
Latent Area Density (1 to 36)
6
No
No
5
No
No
Print Settings
Background Pattern: None, Arabesque, Fans, Polka Dots, Stars, Mesh, Clouds, Cherry Blossoms, Leaves |
Fans
No
No
Print Settings
Size: Small (36 points), Medium (54 points), Large (72 points) |
54 points
No
No
Print Settings
Print Vertically: On, Off |
Off
No
No
Print Settings
White Letters on Colored Bkg.: On, Off |
On
No
No
Sample Print
No
No
Initialize
No
No
[Adjust TL Code]
Dot Size
4
No
Yes
Dot Density: Standard, Rough
Standard
No
Yes
Initialize
No
No
[Scan Settings]
[LTRR/STMT Original Selection]
Select Manually, Use LTRR Format, Use STMT Format
Use LTRR Format
Yes
Yes
[Remote Scan Gamma Value]
Gamma 1.0, Gamma 1.4, Gamma 1.8, Gamma 2.2
Gamma 1.8
Yes
Yes
[Auto Online]
On, Off
Off
No
Yes
[Auto Offline]
On, Off
Off
No
Yes
[Generate File]
[High Compression Image Quality Level]
Image Level in Text/Photo Mode or Photo Mode: Data Size Priority, Normal, Quality Priority
Normal
Yes
Yes
Image Level in Text Mode: Data Size Priority, Normal, Quality Priority
Normal
Yes
Yes
[OCR (Text Searchable) Settings]*1
Smart Scan: On, Off
On
Yes
Yes
No. of OCR File Name Characters: 1 to 24
24 Char
Yes
Yes
[Trace & Smooth Settings]*1
Outline Graphics: On, Off
On
Yes
Yes
Graphics Recognition Level: Normal, Moderate, High
Normal
Yes
Yes
Background Image Level: Data Size Priority, Normal, Quality Priority
Normal
Yes
Yes
[Specify Minimum PDF Version]
Do Not Specify, 1.5, 1.6, 1.7
Do Not Specify
Yes
Yes
[Format PDF to PDF/A]
On, Off
Off
Yes
Yes
[Optimize PDF for Web]
On, Off
Off
Yes
Yes
[Rights Management Server Settings]
Server URL
(NULL)
Yes
No
User Name
(NULL)
Yes
No
Password
(NULL)
Yes
No
Use Password for Each User: On, Off
Off
Yes
No
[Document Scan Lock Operational Settings]*1
Use Document Scan Lock/Embedded Info.: On, Off
On
Yes
Yes
Use Document Scan Lock: On, Off
On
Yes
Yes
Multiple Embedded Information Action: Continue Job, Cancel Job
Cancel Job
Yes
Yes
Restrict Options: On, Off
Off
Yes
Yes
*1
Indicates items that appear only when the appropriate optional product is available for use.
*2
Indicates information that is delivered only if the number of output trays is the same for the machine that is sending device information and the device receiving the information.
*3
Indicates items with no serial number or ID/user name.
