If you want to transmit using ECM, it is necessary that ECM Transmission be set in both the destination machine and this machine. This function does not operate unless ECM is set in both machines.)
(Settings/Registration).|
Even when you set ECM, errors can sometimes occur due to a poor telephone line connection.
If there is trouble with the line, it will take more time to receive the documents.
