If <Use IPv4> in [IPv4 Settings] in [Preferences] is set to 'Off' (see "TCP/IPv4 Settings"), you cannot set the Cascade Copy mode.
(Settings/Registration).
(numeric keys) → press [OK].|
Set the same Department ID and PIN as the machine for the cascade copy printer. (See "Specifying Department ID Management.")
You cannot delete a cascade copy printer while cascade copying with the printer.
