Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Output Report]
[TX/RX User Data List]
Yes, No
Yes
No
[Fax User Data List]*1
Yes, No
Yes
No
[Common Settings]
[Register Favorite Settings]
Checking Settings
Location to Register Button: M1 to M18
No
Yes
Show Comments: On, Off
Off
No
Yes
Name, Comment
No
Yes
[Edit Favorite Settings]
Delete, Check Content, Rename (Name, Comment): M1 to M18
No
Yes
Off
No
Yes
[Display Confirmation for Favorite Settings]
On, Off
On
No
No
[Default Screen]
Standard, One-Touch, Favorite Settings, Address Book
Standard
No
No
[Change Default Settings]
Register, Initialize
No
No
[Register Options Shortcuts]
Shortcut 1: Each mode, Unassigned
2-Sided Original*2
No
No
Shortcut 2: Each mode, Unassigned
Different Size Originals*2
No
No
[TX Report]
For Error Only, On, Off
For Error Only
Yes
Yes
Report with TX Image: On, Off
On
Yes
Yes
[Communication Management Report]
Auto Print (100 Transmissions): On, Off
On
Yes
Yes
Specify Print Time: On, Off
Off
Yes
Yes
Timer Setting: 00:00 to 23:59
(NULL)
Yes
Yes
Send/Receive Separate: On, Off
Off
Yes
Yes
[TX Terminal ID]
TX Terminal ID: Print, Do Not Print
Print
Yes
Yes
Print Position: Inside, Outside
Outside
Yes
Yes
Display Destination Unit Name: On, Off
On
Yes
Yes
Telephone # Mark*1: Fax, TEL
Fax
Yes
Yes
[Delete Failed TX Jobs]
On, Off
On
Yes
Yes
[Retry Times]
0 to 5 times
3 times
Yes
Yes
[Data Compression Ratio]
High Ratio, Normal, Low Ratio
Normal
Yes
Yes
[YCbCr TX Gamma Value]
Gamma 1.0, Gamma 1.4, Gamma 1.8, Gamma 2.2
Gamma 1.8
Yes
Yes
[Use Divided Chunk Send for WebDAV TX]
On, Off
On
Yes
Yes
[Confirm SSL Certificate for WebDAV TX]
On, Off
Off
Yes
No
Add Items to Verify
CN: On, Off
Off
Yes
No
[Limit New Destination]
Fax: On, Off
Off
Yes
Yes
E-Mail: On, Off
Off
Yes
Yes
I-Fax: On, Off
Off
Yes
Yes
File: On, Off
Off
Yes
Yes
[Always Add Device Signature to Send]*1
On, Off
Off
Yes
Yes
Restrict File Formats: On, Off
On
Yes
Yes
[E-Mail/I-Fax Settings]
[Register Unit Name]
Register Unit Name
(NULL)
Yes
No
[Communication Settings]
SMTP RX: On, Off
Off
Yes
Yes
POP: On, Off
On
Yes
Yes
SMTP Server (Server name or IP address)
(NULL)
Yes
No
E-Mail Address
(NULL)
Yes
No
POP Server (Server name or IP address)
(NULL)
Yes
No
POP Address
(NULL)
Yes
No
POP Password
(NULL)
Yes
No
POP Interval
0 min (Off), 1 to 99 mins
0 mins
Yes
No
[Authent./Encryption]
POP AUTH Method: Standard, APOP, POP AUTH
Standard
Yes
Yes
POP Authentication Before Send: On, Off
Off
Yes
Yes
Allow SSL (POP): On, Off
Off
Yes
No
SMTP Authentication (SMTP AUTH): On, Off
Off
Yes
No
User Name
(NULL)
Yes
No
Password
(NULL)
Yes
No
Allow SSL (SMTPReceive): Always SSL, On, Off
Off
Yes
No
Allow SSL (SMTP Send): On, Off
Off
Yes
No
Display Auth. Screen When Send: On, Off
Off
Yes
No
[Confirm SSL Certificate for SMTP TX]
On, Off
Off
Yes
No
Add Items to Verify
CN: On, Off
Off
Yes
No
[Confirm SSL Certificate for POP RX]
On, Off
Off
Yes
No
Add Items to Verify
CN: On, Off
Off
Yes
No
[Maximum Data Size for Sending]
0 (Off), 1 to 99 MB
3 MB
Yes
Yes
[Default Subject]
Default Subject
Yes
Yes
[Use SMTP Authentication for Each User]
On, Off
On
Yes
No
[Specify Authentication User Dest. to Reply]
On, Off
Off
Yes
No
[Set Authentication User Dest. to Sender]
On, Off
On
Yes
No
[Allow Unregistered Users to Send E-Mail]
On, Off
Off
Yes
Yes
[Full Mode TX Timeout]
1 to 99 hrs
24 hrs
Yes
Yes
[Print MDN/DSN upon Receipt]
On, Off
Off
Yes
Yes
[Use Send via Server]
On, Off
Off
Yes
Yes
[Allow MDN Not via Server]
On, Off
On
Yes
Yes
[Restrict TX Destination Domain]
Restrict Sending to Domains: On, Off
Off
Yes
Yes
Permitted Domains: Register, Details/Edit, Delete
Yes
Yes*3
Domain Name
Send to Subdomain: Allow, Reject |
Yes
Yes
[Autocomplete for Entering E-Mail Addresses]
On, Off
On
No
Yes
[Fax Settings]*1
[Default Screen]
Standard, Address Book
Standard
No
No
No
No
Density
No
No
Original Type
No
No
Shortcut 3: Each mode, Unassigned
2-Sided Original*2
No
No
Shortcut 4: Each mode, Unassigned
No
No
[Register Sender Name (TTI)]
01 to 99: Register/Edit, Delete
Yes
No
[Use Auth. User Name as Sender Name]
On, Off
Off
No
Yes
[ECM TX]
On, Off
On
Yes
Yes
[Set Pause Time]
1 to 15 sec
2 sec
Yes
Yes
[Auto Redial]
On, Off
On
Yes
Yes
Set Details: Redial Times (1 to 10 times)
2 times
Yes
Yes
Set Details: Redial Interval (2 to 99 mins)
2 mins
Yes
Yes
Set Details: Redial When TX Error (Error and 1st Page, All Pages, Off)
Error and 1st Page
Yes
Yes
[Check Dial Tone Before Sending]
On, Off
On
Yes
Yes
[Fax TX Report]
For Error Only
Yes
Yes
On
Yes
Yes
[Fax Activity Report]
Auto Print (40 Transmissions): On, Off
On
Yes
Yes
Off
Yes
Yes
00:00
Yes
Yes
Off
Yes
Yes
[Set Line]
[Line 1] to [Line 4]
If only the Super G3 FAX Board is installed:
Line 1
Yes
No
If the Super G3 FAX Board and Super G3 2nd Line Fax Board are installed:
Line 1, Line 2
Yes
No
If the Super G3 FAX Board, Super G3 2nd Line Fax Board, and Super G3 3rd/4th Line Fax Board are installed:
Line 1, Line 2, Line 3, Line 4
Yes
No
[Register Unit Telephone Number]
User Telephone No.
(NULL)
Yes
No
Register Unit Name
(NULL)
Yes
No
[Select Line Type]
Pulse, Tone
Tone
Yes
No
[Select TX Line]
Line 1: Priority TX, Prohibit TX
Line 1:
Priority TX |
Yes
No
Line 2: Priority TX, Prohibit TX
Line 1: Priority TX
Yes
No
Line 3: Priority TX, Prohibit TX
Line 4: Priority TX, Prohibit TX
Line 1: Priority TX
Yes
No
[TX Start Speed]
33600 bps, 14400 bps, 9600 bps, 7200 bps, 4800 bps, 2400 bps
33600 bps
Yes
Yes
[PIN Code Access]
On, Off
Off
Yes
Yes
[Confirm Entered Fax Number]
On, Off
Off
Yes
Yes
[Allow Fax Driver TX]
On, Off
On
Yes
Yes
[Remote Fax TX Settings]*1
[Remote Fax Server Address]
IP address or host name (48 characters maximum)
(NULL)
Yes
No
[TX Timeout]
1 to 99 hrs (one hour increments)
24 hrs
Yes
Yes
[No. of TX Lines]
1 to 4 Line
1
Yes
No
[Select Priority Line]
Auto, Line 1, Line 2*4, Line 3*4, Line 4*4
Auto
Yes
No
[Remote Fax Settings]
[Use Remote Fax]
On, Off
Off
Yes
Yes
*1
Indicates items that appear only when the appropriate optional products are available for use.
*2
If you are using the imageRUNNER ADVANCE 4035/4025, this item appears only when the appropriate optional product is available for use.
*3
Indicates item that is not delivered as device information.
*4
Displays according to the number of lines set in [No. of TX Lines].
