(Settings/Registration).
[Auto]:
The image is automatically reduced by a suitable reduction ratio. This ratio can range from the value set for <Reduction %>, up to 100% of the received document size.
[Fixed]:
The image is reduced by the reduction ratio set for <Reduction %>.
[Vertical & Horizontal]:
The image is reduced in both the vertical and horizontal directions.
[Vertical Only]:
The image is reduced in the vertical direction only.
If the area of the image which exceeds the printable area is less than 1/2" (12 mm), the image will not be printed, regardless of the settings you set for Reduce Fax RX Size.
