» Settings/Registration » Function Settings » Common » Print Settings » Specifying the Default Settings for Printing from the Remote UI
You can change the default settings for printing files stored in a mail box from the Remote UI.
Press [Function Settings] → [Common] → [Print Settings].
Press [Local Print Default Settings].
4.
Specify the settings → press [OK].
[Select Paper]:
Select the desired paper.
[No. of Prints]:
Set the desired number of prints. The number of prints can be set from 1 to 9,999.
[Finishing]:
Select the type of collating.
[2-Sided Printing]:
Set whether to use 2-sided printing.
[Delete File After Printing]:
Set whether to have a file automatically deleted after it is printed.
[Merge Files and Print]:
When multiple files are selected, set whether to merge and print the files as one file.
To change the default settings for Access Stored Files, see "Specifying the Stored File Settings."
