Category
Top » Settings/Registration » Preferences » Timer/Energy Settings » Setting the Sleep Mode Exit Time
Category Top
Flow of Operations on the Settings/Registration Screen
Flow of Operations for Administrators
Flow of Operations for General Users
Settings/Registration Table
Preferences
Adjustment/Maintenance
Function Settings
Function Settings: Copy
Function Settings: Printer
Function Settings: Send
Function Settings: Receive/Forward
Function Settings: Store/Access Files
Function Settings: Encrypted Secure Print
Set Destination
Management Settings
Preferences
Paper Settings
Registering the Paper Type for a Paper Source
Distinguishing A5R and STMTR Paper
Distinguishing B5 and EXEC Paper
Registering/Editing Custom Paper Types
Designating the Envelope Type
Registering Multi-Purpose Tray Defaults
Registering/Editing/Deleting Custom Paper Sizes
Display Settings
Default Screen at Startup
Default Screen (Status Monitor/Cancel)
Switching the Copy Basic Features Screen
Display Fax Function
Store Location Display Settings
Enabling the Language/Keyboard Switch
Changing the Display Language/Keyboard on the Touch Panel Display
Displaying the Remaining Paper Message
Number of Copies/Wait Time Status Display
Clean the Original Scanning Area Screen Prompt
Setting the Default Display of the Paper Type Selection Screen
mm/Inch Entry Switch
Displaying the Current Department ID/User Name
Current Time Adjustment
Current Date and Time
Time Format
Auto Reset Time
Default Display after Auto Reset
Auto Sleep Time
Energy Consumption in the Sleep Mode
Weekly Timer Settings
Silent Mode Time
Accessibility
Key Repetition Settings
Inverting the Screen Colors
Adjust Image Quality
Automatic Gradation Adjustment
Correct Density
Fine Adjust Zoom
Adjust Action
Saddle Stitch Staple Repositioning
Saddle Stitch Position Adjustment
Adjusting the Paper Folding Position
Maintenance
Automatic Feeder Cleaning
Function Settings
Common
Paper Feed Settings
Enabling Paper Drawer Auto Selection
Matching the Print Side for 1-Sided and 2-Sided Printing
Enabling Timeout for Suspended Jobs
Paper Output Settings
Output Tray Designation
Alternating the Print Output (Offset Jobs)
Inserting a Job Separation Sheet between Print Jobs
Inserting a Job Separation Sheet between Copy Sets
Outputting Different Sized Papers to the Same Output Tray
Print Settings
Setting the Printing Priority
Specifying the Default Settings for Printing from the Remote UI
Outputting Reports with Two-Sided Printing
Registering Forms for the Superimpose Image Mode
Registering/Editing/Deleting User-Defined Text for Page Numbers and Watermarks
Scan Settings
Distinguishing LTRR and STMT Originals
Setting the Gamma Value for Remote Scans
Automatically Enabling the Remote Scanner Function
Auto Offline
Generate File
High Compression Image Quality Level
Settings for Creating Searchable PDF/XPS
Trace & Smooth Settings
Specifying the Minimum Version When Generating a PDF
Formatting PDF Files to PDF/A
Optimizing PDF for Web
Copy
Registering/Editing/Deleting Favorite Settings Buttons
Changing/Initializing the Default Settings for the Copy Function
Registering Shortcut Keys
Registering Express Copy Shortcut Buttons
Enabling Auto Collating
Enabling Auto Orientation
Copying with the Printed Image Mode
Setting a Printer for Cascade Copying
Cascade Copy Communication Timeout
Send
Outputting Reports
Common Settings
Displaying a Confirmation Screen When Recalling Favorite Settings
Changing the Default Screen for Send
Changing the Default Settings for Send
Send TX Report
Communication Management Report
Printing the TX Terminal ID
Automatically Deleting Failed Jobs
Number of Retry Attempts
Data Compression Ratio
Gamma Value for YCbCr Send Jobs
Dividing Data Into Chunks When Sending with WebDAV
Confirming the SSL Server Certificate When Sending with WebDAV
E-Mail/I-Fax Settings
Registering the Unit's Name for E-Mail/I-Fax
Common Communication Settings for E-Mail/I-Fax
Confirming the SSL Server Certificate When Sending with SMTP
Confirming the SSL Server Certificate When Receiving with POP
Maximum Data Size for Send
Default Subject
Applying SMTP Authentication for Each User
Setting an Authorized User E-Mail Address as the Reply-to Destination
Setting an Authorized User E-Mail Address as the Sender
Allowing Users Logged In as Guests to Send
Full Mode TX Timeout
Printing MDN/DSN upon Receipt
Sending Via a Server
Allowing MDN Not Via Server
Setting Autocomplete for E-mail Address Entry
Specifying the Fax Settings
Changing the Default Screen for Fax
Changing the Default Settings for the Fax Function
Registering/Editing/Deleting Sender Names
Setting the Authenticated User Name as the Sender Name (TTI)
Enabling ECM Transmission
Pause Time
Enabling Auto Redial
Checking the Dial Tone before Sending
Fax TX Report
Fax Activity Report
Fax Line Settings
Setting the Line to Use when Sending
Send Start Speed
PIN Code Access
Remote Fax TX Settings
Enabling Remote Fax
Receive/Forward
Outputting Reports
Common Settings
2-Sided Printing
Paper Drawer Selection
Reducing a Received File
Printing Received Images with the 2 On 1 Layout
Printing Footer Information on a Received Document
Handling Files That Fail to Be Forwarded
Forwarding Settings
Storing Forwarding Settings
When Forwarding Destinations Do Not Match the Forwarding Conditions
Editing Forwarding Settings
Printing Forwarding Settings
Specifying the Fax/I-Fax Inbox Settings
Always Send Notice for RX Errors
Enabling ECM Reception
Fax RX Report
Confidential Fax Inbox RX Report
Setting the Receive Start Speed
Setting the Receive Password
Store/Access Files
Common Settings
Specifying the Scan and Store Settings
Specifying the Stored File Settings
Mail Box Settings
Memory Media Settings
Set Destination
Printing the Address Lists
Register Destinations
Registering an E-Mail Address
Registering a Fax Number
Registering an I-Fax Address
Registering a Group Address
Addresses Obtained via a Server
Editing Address Details
Deleting Addresses
Naming an Address Book
Registering One-Touch Buttons
Registering/Editing One-Touch Buttons
Deleting One-Touch Buttons
Changing the Default Display of the Address Book
LDAP Server Settings
Registering an LDAP Server
Editing LDAP Server Settings
Registering/Editing LDAP Search Attributes
Printing LDAP Server Settings
LDAP Server Auto Search
Obtaining the Remote Address Book
Remote Address Book
Remote Address Book Server Address
Fax TX Line Auto Select Adjustment
Collapse all|Expand all
Press [Preferences] → [Timer/Energy Settings] → [Sleep Mode Exit Time Settings].
Enter a time → press [OK].
Enter the time in 24-hour notation as four digits (including zeros) without a space.
Examples: 7:05 a.m. → 0705, 11:18 p.m. → 2318
If you make a mistake when entering the time, enter another four digit number.
You can also press (Clear) to clear the incorrect values.
