» Settings/Registration » Function Settings » Copy » Registering/Editing/Deleting Favorite Settings Buttons
You can register up to nine combinations of favorite copy settings.
To register/edit a favorite settings button, set the Copy mode in advance.
Press [Function Settings] → [Copy] → [Register/Edit Favorite Settings].
To register a favorite settings button:
To edit a favorite settings button:
To delete a favorite settings button:
If you want to change the name of a button, select the button to change → press [Rename] → enter the new name.
Select a button ([M1] to [M9]) to register copy settings → press [Register].
Press [Yes].
If you press [Check Content], the existing registered settings appear.
Select a button ([M1] to [M9]) to overwrite settings → press [Register].
Press [Yes].
Select a button ([M1] to [M9]) to delete → press [Delete].
Confirm the contents to be deleted.
Press [Yes].
The name for the button is not deleted. To change the name of the button, press [Rename].
Press [Close].
