Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book|
Size of Received Document
Paper Size Priority
11" x 17"
11" x 17" → LTR* → LTRR* → LGL* → STMTR x 2
LGL
LGL → LTR x 2 → LTRR x 2 → STMTR x 2 → 11" x 17"
LTR
LTR → LTRR → LGL → STMTR x 2 → 11" x 17"
STMT
STMTR → LTR → LTRR → LGL → 11" x 17"
Received documents can be printed on the following paper sizes and paper types:
Size: 11" x 17", LGL, LTR, LTRR, or STMTR
Paper Types: plain, recycled, color, or custom paper type (paper with the following settings; Paper Weight: 64 to 90 g/m2, Type: Normal, Finish: Uncoated or Recycled)
You can specify each paper drawer for the fax function. The default setting is 'On', except for the multi-purpose tray. (See "Enabling Paper Drawer Auto Selection.")
You can set the machine to reduce received documents in 1% increments between 75% to 97% if the document is larger than any of the available paper sizes. (See "Reducing a Received File.")
You can change the order of paper selection. (See "Paper Drawer Selection.")
You can set the machine to print received documents on both sides of the paper. (See "2-Sided Printing.")
