To edit an entry in the Address Book, select the entry from the list under [Address Book] → click [Edit].
Depending on the fax model, you can click [Settings] and set a subaddress.
You can register up to 3000 personal (single) entries.
To delete a registered personal address from the address book, select a personal address from the recipient list in the [Select Recipient from Address Book] dialog box, and click [Delete].
If you specify two fax numbers for one person, two fax numbers for that person are displayed in the list under [Address Books].
The display may vary according to the operating system and system environment.
