You can search for and specify addresses registered in the address book for this machine.
Press [Fax] → [Address Book].
Select the destination → press [OK].
You can select multiple destinations.
For instructions on searching for destinations registered in the Address Book, see
"Address Book Screen."
If you select a destination that is stored with an access number, press [Access No.] and then enter the access number using
![](./images/book_images/b_in_0.jpg)
![](./images/book_images/b_in_9.jpg)
(numeric keys). If you press [Addresses without Access Number], the destinations that are not managed with an access number are displayed.
If you select only one destination, press ![](./images/book_images/b_in_Start.jpg) (Start) to send from the Address Book screen.
