If the machine is connected by bidirectional communication, the settings for this procedure are disabled. Follow the procedure in "Verifying the Fax Information" to automatically set the options.
Be sure to select only those options that are actually installed in the fax.
If you close the [Printer Info] dialog box without clicking [Apply Changes] the settings you have made will not be saved.
