You cannot insert a pause at the beginning of a number.
If you enter a pause at the end of the number, the pause is always 10 seconds long.
You can use multiple lines in the following cases:
If the Super G3 2nd Line Fax Board is installed in addition to installing the Super G3 FAX Board, or the Super G3 3rd/4th Line Fax Board is installed in addition to installing the Super G3 2nd Line Fax Board and Super G3 FAX Board.
If [No. of TX Lines] is set to two or more lines in [Remote Fax TX Settings] when using the Fax function with the Remote Fax Kit (See "Remote Fax TX Settings.")
(numeric keys),
, and
