Faxing methods may vary according to the application you are using. For details, see the instruction manuals provided with the application.
In Mac OS X 10.5.x, the [Page Setup] dialog box may not be displayed, depending on the application you are using. If this is the case, skip to step 4. You can specify [Paper Size] and [Orientation] in the [Print] dialog box.
To change a recipient name or fax number that has already been added, select the recipient from [Recipient List] and click [Edit Recipient].
] → [OK].
For information on using the address book, see "Registering a Person in an Address Book," "Registering a Group in an Address Book," "Importing an Address Book," and "Exporting an Address Book."
For details about how to attach a cover sheet, see "Attaching a Cover Sheet."
Some printer models enable you to stop printing from a printer status confirmation/print cancelation display (see "Status Monitor/Cancel").
To stop sending data that is waiting to be output from Mac OS, click the printer icon in the Dock → click the name of the file you want to stop sending → click [Delete].
The display may vary according to the operating system and fax driver version you are using.
