You can change the settings for a recalled send job.
If there are multiple destinations stored in one log, the order of the destinations shown in the list may not correspond to the order in which they were set.
Send settings are counted as single recent send settings until the following times:
When you press the control panel power switch
When you press
![]() When you press
![]() When the Auto Clear mode activates
When the Auto Sleep time has elapsed
If you set [Manage Address Book Access Numbers] to 'On', you cannot recall settings from memory. (See "Managing the Address Book with Access Numbers.")
If you set any address type to 'On' in [Limit New Destination], the currently stored Previous Settings are deleted. (See "Restricting Sending to New Addresses.")
The three most recent settings that were stored in memory are not deleted even when the main power is turned OFF.
