Category
Top » Fax » Sending a Fax from a Computer (Windows) » System Requirements
Category Top
Sending/Receiving a Fax
Overview of This Function
Additional Lines
Canceling a Job
Specifying Destinations
Entering a New Fax Number
Storing New Addresses
Storing Fax Numbers
Storing Group Addresses
Assigning Shortcuts
Setting the Resolution
Switching to Direct Sending
Setting Original Type
2-Sided Original
Book → 2 Pages
Different Size Originals
Adjusting Density Manually
Adjusting Background Density
Adjusting the Image Sharpness
Changing the Zoom Ratio
Erase Frame
Job Build
Delayed Send
Preview
Finished Stamp
Job Done Notice
Processing Received Documents
Receiving Documents
Setting the Memory Lock Mode
Forwarding Received Documents
Available Paper Sizes
Sending with a Subaddress
Using a PIN Code
Fax Information Services
When Problems Occur
Trouble Sending Fax Documents
Trouble in Other Situations
Questions & Answers
System Requirements
Installation
Setting the Fax Options
Faxing Fundamentals
Faxing
Viewing the Online Help
Using Subaddresses for Secure Transmission
Setting the Fax Send Time
Attaching a Cover Sheet
System Requirements
Installation
Verifying the Fax Information
Faxing Fundamentals
Faxing
Setting the Output Range
Importing an Address Book
Exporting an Address Book
Collapse all|Expand all
System Requirements
The following system environments are necessary in order to use the fax driver.
Operating Systems:
Windows 2000
Windows XP
Windows Server 2003
Windows Server 2008
Windows Vista
Windows 7
Computer:
Any computer that runs the above systems
Memory:
Any memory with the capacity required to operate the compatible operating systems
Supported operating systems may differ according to the fax driver version you are using.
Depending on the printer model, you may need to specify a queue as described below.
LPR
For Windows TCP/IP, enter either <Print>, <Hold>, or <Direct> as the queue.
RAW
The following four port numbers are available:
9100: Enter either <Print>, <Hold>, or <Direct> as the queue.
9101: The queue will be set to <Direct>.
9102: The queue will be set to <Print>.
9103: The queue will be set to <Hold>.
SMB
Select any of the three queues displayed after selecting a printer from the network tree.
