You can print files directly from a USB memory device that is connected to the printer.
You can change the settings when printing.
You can change the default print settings and default file display sorting criteria. Settings that are often used can be conveniently set in advance as defaults.
Remove the USB memory device after printing has stopped. Use the correct method to remove the USB memory device.
In order to use USB memory devices, the following settings are necessary.
Set [MEAP Driver] to [Off].
Enable [USB Direct Print] under [USB Direct Print Settings] in the Remote UI.
About USB memory support
The file format FAT32 is supported only.
USB memory drives cannot be read by this printer if:
these drives are partitioned
these drives contain encrypted data
