You can select whether to print on one side or both sides of each sheet of paper.
The default setting for [Print Style] is [2-sided printing].
Paper Type
Paper Size
Plain paper
(16.0 to 27.9 lb Bond (60 to 105 g/m²))
Heavy paper
(26.6 lb Bond to 60.3 lb Cover (100 to 163 g/m²))
Standard size paper
A4, B5, A5*, Legal, Letter, Executive, Foolscap and 16K Custom size paper:
Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm), long edges 8.27 to 14.00 in. (210.0 to 355.6 mm) |
The paper can be loaded only in landscape orientation (when the long edges of the paper are parallel to the front side of the printer).
Before performing 2-sided printing, see "Attention (1-sided Printing and 2-sided Printing)."
The default setting for [Print Style] is [2-sided Printing]. You can also change the default setting to [1-sided Printing]. For instructions on changing the default settings, see "Configuring the Default Print Settings."
Note
The display may vary according to the operating system, as well as the type and version of the printer driver.
