You can print data by selecting the saved box or job.
You can check or operate the jobs stored in a box. You can perform operations of Resume (Print) and Delete. You can also check the jobs in detail. This operation is performed from the Remote UI.
You can change the name of the box in which data is saved or password. This operation is performed from the Remote UI.
About stored jobs
The stored jobs can be displayed or operated only when the SD card is installed, and [SD Card] is set to [On]. For details on the settings for [SD Card], see "[Setup] Menu ([Control Menu] Options)."
The saved jobs are saved on the SD card even after printing, and they are not deleted even after turning the printer OFF. When you want to delete the saved jobs, use the Remote UI.
Up to the total of 1000 jobs in all the boxes can be saved.
You can change the name of the stored job in the printer driver before printing.
Stored jobs can be deleted automatically by setting a length of time to pass between storing of the jobs and their deletion. On how to set the length of this time, see "Automatically Deleting Files Stored in a Box."
Since processing for deleting stored jobs is performed in background, the screen display does not always show the actual state depending on your system environment. For example, even if "0" is displayed as number of jobs stored in a box, you may not be able to store new jobs in the same box. In this case, wait for some time and then try again the job storing operation.
When the amount of data or number of jobs that you can save on the SD card exceeds the limit
The message <Cannot store.> is displayed. When the message is displayed, perform the following procedure.
Operating the Remote UI
