1.Printer Selection
Selects the printer to use from those previously added to the [Printing] pane of the [Print & Fax] or [Print & Scan] dialog box in the [System Preferences].
2.Presets
Combinations of frequently used settings can be saved as presets. These saved presets can then be selected for printing (see "Using [Presets] for Printing").
3.Save As PDF
Saves the document as a PDF file.
4.Copies
Specifies the number of copies to print.
5.Collated
If two or more copies are to be printed, enables them to be output in sets.
6.Pages
Specifies the range of pages to be printed.
7. Output Paper Size
Enables you to select the paper size actually output from the printer. You can enlarge or reduce documents to match the output paper size (see "Scaling Documents").
The displays may differ between operating systems, printer driver types, and functions.
If the above functions cannot be set in the upper part of the [Print] dialog box, display and set them in the [Copies & Pages] preferences pane or the [Page Setup] dialog box.
