Paper Type
Paper Size
Plain paper
(16.0 to 27.9 lb Bond (60 to 105 g/m²))
Heavy paper
(26.6 lb Bond to 60.3 lb Cover (100 to 163 g/m²))
Standard size paper
A4, B5, A5*, Legal, Letter, Executive, Foolscap and 16K Custom size paper:
Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm), long edges 8.27 to 14.00 in. (210.0 to 355.6 mm) |
The paper can be loaded only in landscape orientation (when the long edges of the paper are parallel to the front side of the printer).
Before performing 2-sided printing, see "Attention (1-sided Printing and 2-sided Printing)."
Do not touch the paper during 2-sided printing until it is completely output. The paper is first partially output after the front side is printed, and then it is fed again to be printed on the back side.
Be sure to close the output selection cover before performing 2-sided printing.
Printing on the back side of paper whose front side is already printed
This printer enables you to perform 2-sided printing by manually inserting the back side of the paper* whose front side was previously printed even if the paper cannot be used for 2-sided printing.
When printing on the back side of paper whose front side was previously printed, flatten out any curled paper and load one sheet of paper at a time in the multi-purpose tray.
The default setting for [Print Style] is [2-sided printing]. You can save the 1-sided printing setting as a preset. For details, see "Using [Presets] for Printing."
The screen may vary according to the operating system, as well as the type and version of the printer driver.
