e-ManualTopSite mapHelp
Chapter Top
Printing Fundamentals
Printing
Setting the Printer Options
Viewing the Online Help
Printing Functions
Common Functions
[Page Setup] Tab
[Finishing] Tab
[Paper Source] Tab
[Quality] Tab
[Device Settings] Tab
Scaling Documents
1-sided Printing and 2-sided Printing
Attention (1-sided Printing and 2-sided Printing)
Booklet Printing
Poster Printing
Watermark Printing
Printing from a Computer (Macintosh)
Printing
Viewing the Driver Guide
Printing Functions
Common Functions
[Layout] Preferences Pane
[Finishing] Preferences Pane
[Quality] Preferences Pane
Scaling Documents
1-sided and 2-sided Printing
Using [Presets] for Printing
Setting Priority (When Specifying the Same Item Using Multiple Methods)
Functions Which Can Be Specified from the Control Panel
Printing without the Printer Driver (Direct Print)
Printing the PDF File Using the Direct Print Function
Printing the PS/EPS File Using the Direct Print Function
Printing the TIFF/JPEG File Using the Direct Print Function
Printing the XPS File Using the Direct Print Function
Direct Printing from Command Prompt
Printing Files Directly from USB Memory Devices (USB Direct Print)
Printing Directly from USB Memory Device
Print Setting Menu List
Changing the Default Print Settings and File Sorting Criteria
Remove the USB Memory Device
Receiving E-mail Data on the Mail Server and Printing (E-mail Print)
How to Specify the Settings for E-mail Print
Attention (How to Specify the Settings for E-mail Print)
Receiving and Printing E-mails Manually
Printing the E-mail Receive Log List
Attention (Printing E-mail Sending/Receiving History)
When E-mail Print Fails
Printing Files from the Printer Using FTP Client
Specifying a Password for a Document and Printing (Secured Print)
Attention (Specifying a Password for a Document and Printing (Secured Print))
Saving a Document in the SD Card in the Printer (Stored Job Print)
Performing a Stored Job Print Using the Control Panel of the Printer
Displaying or Operating the Jobs Stored in a Box (Resume/Delete)
Automatically Deleting Files Stored in a Box
Changing the Box Settings
Giving Priority to a Print Job (Interrupt Printing)
Top » Useful Printing Functions » Giving Priority to a Print Job (Interrupt Printing)
07E3-075
This mode is used for pausing the job currently being processed and start printing the specified job on ahead. The paused print jobs are saved on the SD card in the printer and printed again after the print job that interrupted is completed.
Select [Interrupt Print] from [Output Method] in the printer driver, and then print.
If a print job for interrupt printing has already being processed
You cannot give priority anymore to another print job.
