e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Accepting Only Encrypted Secure Printing
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Available Administrator Settings Table (Touch Panel Display)
0UKW-13X
If the administrator is specified, you can restrict operations by general users and allow the administrator to set the settings of each function on Settings/Registration. The settings available for operation vary according to the type of administrator. This section describes the settings in Settings/Registration that each type of administrator can operate.
Preferences
If the administrator is specified, the following settings in [Preferences] can be set only by the administrator.
: Only the administrator can change the settings.
-: Depending on the type of the administrator when using the SSO-H, settings cannot be changed.
System Manager/System Administrator (Administrator)
Network Administrator (NetworkAdmin)
Device Administrator (DeviceAdmin)
[Paper Settings]
[Paper Type Management Settings]
[Display Settings]
[Default Screen after Startup/Restoration]
[Store Location Display Settings]
[ID/User Name Display On/Off]
[Display Remaining Toner Error Message]
[Timer/Energy Settings]
[Date/Time Settings]
[Time Format]
[Quick Startup Settings for Main Power]
[Restrict Auto Reset Time]
[Network]
[Confirm Network Connection Set. Changes]
[TCP/IP Settings]
[IPv4 Settings]
[IPv6 Settings]
[DNS Settings]
[WINS Settings]
[LPD Print Settings]
[RAW Print Settings]
[SNTP Settings]
[FTP Print Settings]
[WSD Settings]
[IPP Print Settings]
[Multicast Discovery Settings]
[Use HTTP]
[SSL Settings]
[Proxy Settings]
[Confirm Dept. ID PIN]
[IPSec Settings]
[NetWare Settings]
[SNMP Settings]
[Dedicated Port Settings]
[Use Spool Function]
[Startup Settings]
[Ethernet Driver Settings]
[IEEE 802.1X Settings]
[Firewall Settings]
[IPv4 Address Filter]
[IPv6 Address Filter]
[MAC Address Filter]
[IP Address Block Log]
[External Interface]
[USB Settings]
Adjustment/Maintenance
If the administrator is specified, the following settings in [Adjustment/Maintenance] can be set only by the administrator.
[Adjust Image Quality]
[Dither Pattern Settings]
[Adjust Toner Volume Used for Color Printing]
Function Settings
If the administrator is specified, the following settings in [Function Settings] can be set only by the administrator.
[Common]
[Print Settings]
[Secure Watermark/Document Scan Lock]*1*2
[Document Scan Lock Operational Settings]*2
[Set Authentication Method]
[Printer]
[Restrict Printer Jobs]
[PDL Selection (Plug-n-Play)]
[Store/Access Files]
[Network Settings]
[Protocol for External Reference]
[Confirm SSL Certificate for Network Access]
[Memory Media Settings]
[Secure Print]
[Simple Authentication Settings]
[Only Allow Encrypted Print Jobs]
*1 The setting names may differ depending on the optional products available for use.
*2 Indicates items that appear only when the appropriate optional equipment is available for use.
Management Settings
If the administrator is specified, the following settings in [Management Settings] can be set only by the administrator.
[User Management]
[System Manager Information Settings]
[Department ID Management]
[Device Management]
[Device Information Settings]
[Device Information Delivery Settings]
[Limited Functions Mode]
[Certificate Settings]
[Display Job Status Before Authentication]
[Display Log]
[Save Audit Log]
[Store Key Operation Log]
[Format Encryption Method to FIPS 140-2]
[License/Other]
[Register License]
[MEAP Settings]
[Remote UI]
[Delete Message Board Contents]
[Remote Operation Settings]
[Use ACCESS MANAGEMENT SYSTEM]
[Register/Update Software]
[Start Setup Guide]
[Data Management]
[Delete Existing Data Settings]
[Initialize All Data/Settings]
[TPM Settings]
For information on the types of administrators, see "Administrator Settings."
