e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Accepting Only Encrypted Secure Printing
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Device Management » Specifying Device Information Delivery Settings » Setting Automatic Delivery
0UKW-13C
You can set to automatically deliver device information at a specified time. You can also select which information to deliver.
Press [Management Settings] → [Device Management] → [Device Information Delivery Settings].
Press [Set Auto Delivery] for <Transmitting Settings> → select [Everyday] or [Specify Days].
If you do not want to set automatic delivery, select [Off] → press [OK] → [OK].
If you select [Everyday]:
If you select [Specify Days]:
Press [Everyday].
Select a number ([1] to [5]).
Enter the start time using - (numeric keys) → press [Next].
You can store up to five different start times.
The time is displayed in 24-hour notation. Enter the time as a four digit number including zeros.
Examples:
7:05 a.m.
→0705
11:18 p.m.
→2318
If you make a mistake when entering the time, enter another four digit number.
Press [Specify Days].
Select a day of the week ([Sun] to [Sat]) → select a number ([1] to [5]).
You can store up to five different start times for each day of the week.
Examples:
7:05 a.m.
→0705
11:18 p.m.
→2318
4.
Specify each setting → press [Next].
Press [On] for an item to deliver that data.
If you press [On] for <Settings/Registration Value>, set <Network Settings>. You can press [Include] → [OK] to deliver the network settings.
5.
Select the destination → press [OK] → [OK].
When delivering device information, the following machines will not update their information:
Machines importing or exporting data via the Remote UI
The client machine which is performing a print job will not update the printer settings.
Machines which could not receive device information because of a power failure or network trouble, will not receive updated information until the first automatic update after the machine recovers.
Device information is not delivered if the machine has entered the shutdown process, even if an automatic delivery time is set.
