Specifying Management Settings for the Memory
0UKW-131
The memory of the machine stores image data for outputting print jobs, and image data for printing reports, job logs, etc. Therefore, it is necessary to manage the data in the memory with strong security measures.
With the machine equipped with functions such as data encryption and data erase, you can manage the data and prevent information leakage to retain security and confidentiality.
The security provided by TPM does not guarantee complete protection of the data and hardware. Note that Canon will not be liable for any failure or damages resulting from the use of this mode.
The machine separates and stores the job data when printing into management information and actual data. The management information is automatically erased when the job is complete, but the actual data is stored in the memory.
With this function, you can completely erase all of the actual data in the memory of the machine by overwriting with 0 data or random data. This is effective in preventing data leakage when replacing or disposing the memory. For more information, see
"Completely Erasing Unnecessary Data from the Memory."
Initializing Registered Information
You can erase (initialize) data stored in the machine such as Settings/Registration information and job history.
(See "Initializing All Data/Settings.")
For information on the optional products required to use this function, see
"Optional Products Required for Each Function."
You can encrypt data stored in the memory such as job data and password information, preventing confidential information leakage from the memory. For more information, see the manual for the HDD Data Encryption Kit.
You can encrypt the password and certificate information managed in the memory using the TPM Settings mode.
(See "TPM Settings.")
