e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Accepting Only Encrypted Secure Printing
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Restricting Access by Authentication » Administrator Settings
0UKW-11H
By specifying the administrator, you can restrict operations by general users on the Settings/Registration screen. You can set the following types of administrator on this machine. For information on the Settings/Registration items available with administrator privileges, see "Available Administrator Settings Table (Touch Panel Display)" and "Available Administrator Settings Table (Remote UI)."
System Manager
System Administrator (Administrator)*
Network Administrator (NetworkAdmin)*
Device Administrator (DeviceAdmin)*
*You can set this when using SSO-H.
System Manager
The System Manager can specify all of the system settings for the machine. As a default, System Manager settings (System Manager ID/System Manager PIN) are set on the machine. Thus, the administrator must log in by entering the System Manager ID and the System Manager PIN on the Settings/Registration screen. The default setting for both the System Manager ID and System Manager PIN is '7654321'. It is recommended that you change both the System Manager ID and System Manager PIN.
For instructions on specifying the System Manager Settings, see "Specifying the System Manager Settings."
The System Administrator (Administrator) can specify all of the system settings for the machine. To specify the authentication settings using SSO-H, set the System Manager Settings and use SMS (Service Management Service) from the Web browser. (See "MEAP.")
The Network Administrator (NetworkAdmin) mainly manages the settings related to the network. You can specify the IP address settings required to connect to the network or the settings for IPSec and SNMP for security.
The Device Administrator (DeviceAdmin) can specify settings such as paper type management settings.
