e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Accepting Only Encrypted Secure Printing
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Device Management
Device Management
0UKW-135
You can store the device information or refer/output the log for previous transmission. Also, various functions are available on this machine by connecting to external device. In addition, the administrator can set restrictions on the usage of those functions.
USB Settings
If you want to use the machine with the USB device, activate the connection settings. Also, you can set whether to use the MEAP driver when connecting the USB device. (See "Using the USB Port.")
If multiple printers are connected via the shared network, you can deliver the device information (management data) stored on the host printer to other client printers. The client machine receives and updates the device information. This enables you to easily manage multiple printers at the same time. (See "Specifying Device Information Delivery Settings.")
Report Settings
The machine stores and manages print jobs and transmission of the device information delivery as a log. From the Report Settings, you can output the log as a report or set so that the report is automatically output. (See "Checking/Printing the Communication Log.")
Remote UI Settings
You can use SSL communication when setting and operating the machine using the Remote UI. (See "Remote UI.")
The administrator can also perform operations that cannot be performed from the control panel, using the Remote UI. The following are examples of such operations:
Restarting the machine
Installing a CA certificate file
Managing (exporting/clearing) the audit log
Importing/exporting Settings/Registration
For information on detailed Remote UI operations and the settings available with administrator privileges on the Remote UI, see "Remote UI."
