e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Accepting Only Encrypted Secure Printing
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Restricting Access by Authentication » Department ID Management
0UKW-11K
You can register a Department ID and PIN (up to seven digits) for each department, and manage the machine by limiting its use to only those who enter the correct Department ID and PIN. This is called Department ID Management. Department IDs and PINs for up to 1,000 departments can be registered. Use Department ID Management to keep track of the print totals for each department.
This section describes the following settings:
Registering the Department ID and PIN
Setting the print page limits
Setting the functions to use Department ID Management for
Checking the print page totals
If you are using SSO-H and set [Department ID Management] to 'On', you may not be able to log on. In this case, change the login service to Default Authentication → set [Department ID Management] to 'Off'. For instructions on setting a login service, see "Setting Application Authentication Information."
If SSO-H is set as the login service, Department ID Management is performed on the Department ID that shares the same user name and password as the one registered for MEAP User Authentication.
The user information registered for the Local Device Authentication system of SSO-H, and the registered Department ID and PIN set for Department ID Management must match. If the registered Department ID and PIN have been changed because information was updated or changed by the Device Information Delivery Settings mode, make sure that you change/update the user information registered for the Local Device Authentication system of SSO-H accordingly. For instructions on registering SSO-H user information, see "Setting the User Information for SSO-H."
If SSO-H is set as the login service, limiting function is not available.
The maximum number of digits that you can store for the Department ID and PIN is seven.
