e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Accepting Only Encrypted Secure Printing
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Preventing Information Leakage » Forced Secure Watermark/Document Scan Lock
0UKW-12K
Secure Watermark/Document Scan Lock mode enables you to prevent information leakage. These modes can be set by administrator so that it is always reflected on the output by the general users.
The administrator can set the Secure Watermark/Document Scan Lock mode for all print jobs, and also set whether to use the Secure Watermark/Document Scan Lock mode for each print job from the printer driver.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
Please note that Canon will not be held responsible for any damages caused by the use of the Document Scan Lock mode or the inability to use the Document Scan Lock mode.
Secure Watermark
This mode enables you to embed text, such as "CONFIDENTIAL," the date and time, or custom characters (a watermark) on the output so that the embedded text appears when printouts are copied. You can prevent unauthorized copying by the third party because you can distinguish between the original and copies of originals.
Original
Print A
(Secure Watermark Is Set)
Copy B
(Copy of Print A)
Document Scan Lock
This mode enables you to embed scan lock information and tracking information on the prints to restrict job operation. When the output with embedded information is scanned, the machine restricts operation according to the specified settings of embedded scan lock information.
With these settings, you can restrict unauthorized copying/printing, and also analyse information in printouts to track who, when, and with which machine the document was output.
You can embed these information using the TL code.
Original
Print
Output
The dots are printed in the background of output.
A TL code is a type of 2-dimensional bar code. A TL code is printed and by changing the arrangement of the dots, digital information is embedded on the output.
The following information can be used with this mode.
Scan Lock Information
When the output with embedded scan lock information is scanned, the machine detects embedded information and restricts unauthorized copying and printing.
Original
Output with Embedded TL Code
(Scan Lock Information)
Jobs are restricted.
Print
Copy/Send/Store
Specify the detailed settings for embedding information beforehand such as whether to set the machine always prohibit copying and printing the document with embedded scan lock information. (See "Document Scan Lock Settings.")
Tracking Information
You can embed tracking information such as date/time, user name, and device name for the job operation.
You can scan printouts with embedded tracking information to analyse who, when, and with which machine the document was output. The information analyzing tool is required to analyze tracking information. For more information, see "Document Scan Code Analyzer for MEAP" in the manual.
You can analyze embedded tracking information in the TL code printed on the output, and find out who, when, and with which printer the document was output. The information analyzing tool is required to analyze tracking information.
(Original)
(Original)
Print
Copy
