e-ManualTopSite mapHelp
Category Top
Preventing Unauthorized Access
Increasing Security
Restricting Access by Authentication
Administrator Settings
Specifying the System Manager Settings
Department ID Management
Specifying Department ID Management
Checking/Printing/Clearing Page Totals
Accepting Jobs with Unknown Department IDs
Accepting B&W Print Jobs without Entering a Department ID
User Setting Information Management (User Setting Information Management Service)
Logging In to the User Setting Information Management Service Page
Deleting the User Setting Information
User Access Control for Advanced Box
Simple Authentication Settings for Secure Print
Setting to Disable Integrated Authentication
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Using an Encryption Method That Complies with FIPS 140-2
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Accepting Only Encrypted Secure Printing
Setting the Control Panel Display
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Delivery Settings
Registering/Deleting/Printing Delivery Destinations
Setting the Receiving Machine
Setting Automatic Delivery
Setting Manual Delivery
Checking/Printing the Communication Log
Setting SSO-H Authentication for Device Information Delivery Settings
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
ACCESS MANAGEMENT SYSTEM
Starting the Setup Guide
Retrieving Audit Logs
Available Administrator Settings Table (Touch Panel Display)
IEEE 2600 Security Standard
Top » Security » Starting the Setup Guide
0UKW-13U
You can configure the machine's initial settings by using the Setup Guide.
When the Setup Guide is started and closed, the machine will restart. Before the machine is restarted, make sure that there are no jobs currently in progress.
This mode is not available if login authentication (authenticated by SSO-H or Department ID Management, or by control cards) is enabled.
Press [Management Settings] → [License/Other] → [Start Setup Guide].
Press [Start].
Press [Start] to restart the machine and display the Setup Guide.
Once all the settings have been configured with the Setup Guide, the machine will once again restart.
The Setup Guide displays the settings to be configured in the following order.
Procedure
Item
Setting Description
Remarks
Required Permission Level
1
<Language/Keyboard Switch>
Select the displayed language and keyboard layout.
General Users/System Managers
2
<Paper Settings>
Set the paper size for each paper drawer.
You can close the Setup Guide here. To close the Setup Guide, press [Skip].
3
<Date/Time Settings>
Set the date and time.
The Log In screen is displayed. Log in as an administrator.
System Manager
4
<Use IP Address>
Specify IPv4 and/or IPv6, and each IP address.
5
<DNS Server Address Settings>
Configure the DNS Server Address Settings, the DNS Host/Domain Name Settings, and the DNS Dynamic Update Settings.
6
<Proxy Settings>
Specify the Proxy Settings.
7
<Register Unit Name>
Enter the name the machine will appear as on the network.
8
<System Manager Information Settings>
Configure the System Manager Settings.
9
<Auto Adjust Gradation>
Automatically adjust the gradation, density, and color settings of the machine.
For more information on the operation, see "Configuring the Machine (Setup Guide)."
