The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
Please note that Canon will not be held responsible for any damages caused by the use of the Document Scan Lock mode or the inability to use the Document Scan Lock mode.
(Settings/Registration).
[On]:
Detects the embedded Document Scan Lock information and embeds additional information.
[Off]:
Does not detect the embedded Document Scan Lock information or embed additional information.
[Continue Job]:
If information A is already embedded in the printed document, the document is printed without embedding the additional information B.
[Cancel Job]:
If information is already embedded in the printed document, the job is canceled.
If you convert a document with a TL code embedded to a generic file format (such as PDF and TIFF) using the functions described in "Scan and Send" or "Scan and Store," the embedded information is not retained. Therefore, when you print the file after it has been converted, the settings in [Document Scan Lock Operational Settings] are not reflected.
