Enter keyword(s) here
Enter a keyword in the entry field which is located at the top of the "Top page" or on the search area in the "Topic page," and then click
![]() In addition, you can refine the search results by entering two or more keywords using the AND search. When entering keywords, enter a space between the keywords.
Example: Toner Message (if you want to display pages which include words, "Toner" and "Message") You can also use the Phrase search by putting double quotes around a set of words.
Example: "toner cartridge"
[Search options]
Click here to use search options. If you want to specify a search scope, select the check box in [Search from below categories:] for the category which you want to search.
In addition, you can select [Case sensitive] and [Differentiate between one-byte and two-byte].
You can use the specified search options by clicking [Search with these conditions]. |
Search result
The search results for a keyword are displayed. If the search results are more than 10 results, you can see the other results by clicking [« Prev], [Next »] or the number which is located below the result. |
The specified search options are applied when searching from the "Top page."
