Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Preventing Information Leakage » Mail Box Settings » Specifying the Mail Box Security Settings
0R9W-20J
You can specify settings to improve the security of files stored in mail boxes.
Forcing Seven Digit Mail Box PINs
The PIN used when storing a file in a mail box can be set using at least one digit. If you set this function to 'On', users are forced to set a seven digit PIN.
Press [Function Settings] → [Store/Access Files] → [Common Settings].
Press [Limit Box PIN to 7 Digits/Restrict Access].
4.
Press [On] → [OK].
Select [Off] if you do not want to force users to set a seven digit mail box PIN.
Changes are only effective after you restart the machine. For instructions on restarting the machine (turning the main power switch OFF, and then ON), see "Main Power and Energy Saver Key."
Allowing Changes to Print Settings upon Storing from the Printer Driver
In <Print When Storing from Printer Driver> in [Function Settings] (Settings/Registration), you can set whether to print a file when storing it in a mail box from a computer via the printer driver. (See "Mail Box Settings.") If you set this mode to 'Off', the settings for <Print When Storing from Printer Driver> cannot be changed.
Press [Function Settings] → [Store/Access Files] → [Mail Box Settings].
Press [Box Security Settings] → [Display Print When Storing from Printer Driver].
4.
Press [On] → [OK].
Select [Off] if you want to restrict changes to print settings upon storing from the printer driver.
Settings specified from the control panel become effective after the machine is restarted, after the procedure. If <Perform Apply Setting Changes from Settings/Regist.> is displayed on the bottom of the touch panel display, you can press [Apply Set. Chng.] in (Settings/Registration) to restart the machine. For information on restarting the machine using the main power switch, see "Main Power and Energy Saver Key."
If you registered a PIN of fewer than seven digits before you set this function to 'On', you can use the registered PIN. However, to ensure security, register the PIN again using seven digits.
If you set this function to 'On', users are forced to set seven digit PINs for the Memory RX Inbox and Confidential Fax Inboxes.
For instructions on setting a PIN for a mail box, see "Mail Box Settings."
For instructions on setting PINs for the Memory RX Inbox and Confidential Fax Inboxes, see "Specifying the Fax/I-Fax Inbox Settings."
