Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » IEEE 2600 Security Standard
0R9W-21F
This section describes the IEEE 2600 defined security requirements and how the functions of this machine meet these requirements.
Security Requirement
Function on the Machine
Description
User Authentication/User Information Management:
Preventing Unauthorized Use of the Machine By Authenticating Users
User Authentication
User Authentication enables you to manage the machine's users by performing authentication with registered user names and passwords.
Manages user information such as user names and passwords, as well as Department IDs and roles (privileges).
Access Restrictions:
Restricting Use of Functions By User
ACCESS MANAGEMENT SYSTEM
You can set access restrictions for functions, such as the Print or Copy function, for each user.
Audit Log*2:
Overseeing Security-Related User Operations
Generate/Export Audit Logs
You can generate user authentication logs and job logs, and export the logs in CSV format from the Remote UI.
Temporary Data Erase:
Completely Erasing Unnecessary Temporary Data from the Memory
Complete Data Erase
You can erase unnecessary data from the memory of the machine by overwriting the data.
Data Protection*3:
Protecting Data and Confidential Information on the hard disk
HDD Data Encryption Kit*1
You can encrypt data stored on the hard disk such as information registered in the Address Book and password information.
Network Data Protection:
Protecting Data Transmissions with Encrypted Communication
IPSec
IPSec protects data sent and received over an IP network from threats such as theft, modification, and impersonation, using security policies created for encrypted communication.
Software Verification:
Self-Verification of Security Functions
IPSec
If IPSec settings are enabled, the self-test for the code module is automatically performed when the machine starts.
*1
Indicates optional products.
*2
[Network]/[Memory Media] for [Scan and Store]/[Access Stored Files] is not included in the scope of the audit.
*3
Files stored in memory media are not encrypted.
