Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Device Management » Specifying Device Information Distribution Settings » Setting the Receiving Machine
0R9W-213
If you want to restore device information to what it was before it was updated, only the data of the very last update is available to be restored.
While receiving and updating device information, the screen indicating that the settings are being updated appears. Operations on this machine cannot be performed until the update completes.
Restricting the Reception of Device Information
Receiving from machines other than imageRUNNER ADVANCE C3330i/C3325i is restricted.
Press [Management Settings] → [Device Management] → [Device Information Distribution Settings].
Press [Restrict Receiving Device Information] for <Receiving Settings> → [On] → [OK].
If you do not want to restrict the reception of device information, press [Off].
4.
Press [OK].
Restoring Device Information
You can restore device information to what it was before it was updated. This is useful when you have accidentally updated the device information.
Press [Restore Data] for <Receiving Settings>.
4.
Select the information to restore → press [Start].
You cannot restore the settings of Workflow Composer to what they were before the device information was updated.
If you do not restore [Settings/Reg. Value] and [Address Book] at the same time, [URL Send Settings] in [Set Fax/I-Fax Inbox] may be erased.
5.
Press [Yes].
6.
Press [OK] → [OK].
Restricting the Type of Information That Is Updated
You can set whether the machine receives and updates the delivered device information.
Press [Restrict Receiving for Each Function] for <Receiving Settings> → specify each setting → press [OK].
Press [On] for an item to set the machine to not receive and update that device information.
Before setting <Settings/Registration Value>, <Dept. ID>, or <Address Book> to 'Off', it is necessary to set a default key in [Preferences] (Settings/Registration). (See "Setting the Key Pair Used With SSL Encrypted Communications.")
4.
Press [OK].
Settings specified from the control panel become effective after the machine is restarted, after the procedure. If <Perform Apply Setting Changes from Settings/Regist.> is displayed on the bottom of the touch panel display, you can press [Apply Set. Chng.] in (Settings/Registration) to restart the machine. For information on restarting the machine using the main power switch, see "Main Power and Energy Saver Key."
