Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Preventing Information Leakage » Forced Secure Watermark/Document Scan Lock » Document Scan Lock Settings » Setting the Document Scan Lock Mode
0R9W-207
The Administrator can specify the TL code for the Forced Document Scan Lock mode and the Printer Driver Document Scan Lock mode. (See "Setting Administrators.")
Forced Document Scan Lock mode:
TL code is always embedded for copy and print jobs by general users.
Printer Driver Document Scan Lock mode:
You can select whether to embed TL Code for each print job which is operated by general users from the printer driver.
When using the TL code, you can embed tracking information that enables you to analyze by whom, when, and with which machine the document was output.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
Please note that Canon will not be held responsible for any damages caused by the use of the Document Scan Lock mode or the inability to use the Document Scan Lock mode.
Press [Function Settings] → [Common] → [Print Settings].
Press [Document Scan Lock Settings].
If the Secure Watermark mode is available for use, press [Secure Watermark/Document Scan Lock].
4.
Select the Document Scan Lock mode.
To select the Forced Document Scan Lock mode:
To select the Printer Driver Document Scan Lock mode:
Press [Forced Document Scan Lock].
If the Secure Watermark mode is available for use, press [Forced Secure Watermark/Doc. Scan Lock].
Press [Set] for the function (<Copy>/<Access Stored Files>/<Printer>) to set the Forced Document Scan Lock mode.
If the Secure Watermark mode is available for use, press [Forced Doc. Scan Lock] for the function (<Copy>/<Access Stored Files>/<Printer>) to set the Forced Document Scan Lock mode.
Press [Printer Driver Document Scan Lock].
If the Secure Watermark mode is available for use, press [Printer Driver Watermark/Doc. Scan Lock].
Press [Set].
If the Secure Watermark mode is available for use, press [Driver Doc. Scan Lock].
5.
Press [Scan Lock Information] → select condition → press [OK].
[Allow All]:
You can embed TL code which enables documents to be copied.
[Prohibit All]:
You can embed TL code which restricts copying documents. You cannot copy documents when [Prohibit All] is detected.
6.
Press [Tracking Information] → specify each setting → press [OK].
[Set]:
You can embed tracking information that enables you to analyze by whom, when, and with which machine the document was output.
[Custom Characters]: Set the text for tracking information.
[Set] for <Password When Analyzing Embedded Info>: Password authentication is requested when analyzing the tracking information.
[Do Not Set] for <Password When Analyzing Embedded Info>: Password authentication is not requested when analyzing the tracking information.
[Do Not Set]:
Tracking information is not embedded.
7.
Select [Magenta] or [Black] for <Color>.
8.
Press [OK].
[Set] is set for <Password When Analyzing Embedded Info> in <Tracking Information> by default. The default password is '7654321'. We recommend that you change the password. If <Password When Analyzing Embedded Info> is [Set], password authentication is requested when analyzing the tracking information using the Document Scan Code Analyzer for MEAP. To strengthen the confidentiality of the information, we recommend that password authentication be set for analyzing the tracking information.
If Printer Driver Document Scan Lock and Forced Document Scan Lock are set for a printer at the same time, Forced Document Scan Lock is given priority.
If you want to use the Document Scan Lock function for each job from the printer driver, on the [Printing Preferences] dialog box, click the [Finishing] tab → [Advanced Settings] → select [On] for [Secure Printing Function of Devices]. For more information, see the on-line help for the printer driver.
