Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Preventing Information Leakage » Forced Secure Watermark/Document Scan Lock » Document Scan Lock Settings » Specifying the Document Scan Lock Operational Settings
0R9W-206
You can specify whether to use the Document Scan Lock mode, and the settings for jobs that affect the retention of embedded information.
This setting can be specified when the Document Scan Lock function is available for use. For information on the optional products required to use the Document Scan Lock function, see "Optional Products Required for Each Function."
The Document Scan Lock mode does not guarantee restriction of unauthorized copying. You may not be able to restrict unauthorized copying or analyze tracking information, depending on the combination of settings and the output, such as a document with an image on the entire page.
Please note that Canon will not be held responsible for any damages caused by the use of the Document Scan Lock mode or the inability to use the Document Scan Lock mode.
Press [Function Settings] → [Common] → [Document Scan Lock Operational Settings].
Specify each setting → press [OK].
<Use Document Scan Lock/Embedded Info>:
[On]:
Detects the embedded Document Scan Lock information and embeds additional information.
[Off]:
Does not detect the embedded Document Scan Lock information or embed additional information.
<Use Document Scan Lock>:
[On]:
When a document with embedded information is scanned, the embedded information is detected and the scan job is canceled automatically.
[Off]:
When a document with embedded information is scanned, the scan job is started even if the document is embedded with [Prohibit All] information.
<Multiple Embedded Information Action>:
[Continue Job]:
If information A is already embedded in the copied/printed document, the document is printed without embedding the additional information B.
[Cancel Job]:
If information is already embedded in the copied/printed document, the job is canceled.
<Rstrct. Func. Affct. Doc. Scan Lock>:
[On]:
To retain the embedded information, the use of functions* that affect the TL code is restricted.
[Off]:
If you set a function* that affects the TL code when attempting to copy, scan, or print a document with embedded information, that job is canceled, and the message <The job was canceled because embedded information was detected.> is displayed on the touch panel display.
For documents without embedded information, the job is carried out in the usual way.
* Refers to functions such as copy (zoom) ratio, page layout, booklet, density, page numbering, copy set numbering, etc., that set reduction/enlargement, and printing and density changes.
If you convert a document with a TL code embedded to a generic file format (such as PDF and TIFF) using the functions described in "Scan and Send" or "Scan and Store," the embedded information is not retained. Therefore, when you print the file after it has been converted, the settings in [Document Scan Lock Operational Settings] are not reflected.
You can analyze the embedded information using the Document Scan Code Analyzer for MEAP that is supplied with the Document Scan Lock Kit. For more information, see the manual for Document Scan Code Analyzer for MEAP.
