Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Preventing Information Leakage » Forced Secure Watermark/Document Scan Lock » Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
0R9W-203
You can select whether to set the Secure Watermark/Document Scan Lock mode for all copy and print jobs, or whether to set the Secure Watermark/Document Scan Lock mode for each print job from a printer driver.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Forced Secure Watermark enables you to set the machine to always print the specified hidden watermark on prints and copies.
Press [Function Settings] → [Common] → [Print Settings].
Press [Secure Watermark Settings].
If the Document Scan Lock mode is available for use, press [Secure Watermark/Document Scan Lock].
4.
Press [Forced Secure Watermark].
If the Document Scan Lock mode is available for use, press [Forced Secure Watermark/Doc. Scan Lock].
5.
Press [Set] for the function (<Copy>/<Access Stored Files>/<Printer>) to set the Forced Secure Watermark mode.
If the Document Scan Lock mode is available for use, press [Forced Sec. Watermark] for the function (<Copy>/<Access Stored Files>/<Printer>) to set the Forced Secure Watermark mode.
6.
Select the type of secure watermark to embed (Watermark, Date, Copy Set Numbering, Serial Number, or ID/User Name).
To select Watermark:
To select Date:
To select Copy Set Numbering:
To select Serial Number:
To select ID/User Name:
Press [Watermark].
Select the watermark type from the drop-down list → press [Next].
If you select [Custom] from the <Watermark Type> drop-down list, press [Enter] → enter the desired text → press [OK] → [Next].
For instructions on entering characters, see "Entering Characters from the Touch Panel Display." If you have registered characters in [Register Characters for Page No./Watermark] in [Function Settings] (Settings/Registration), you can select the characters from the list.
To select Date:
Press [Date].
Select the format of the date from the drop-down list → press [Next].
Press [Copy Set Numbering].
Set the starting number → press [Next].
Press [Serial Number] → [Next].
The Serial Number, which appears at the bottom left of the screen when you press (Counter Check) on the control panel, is printed.
Press [ID/User Name] → [Next].
If a login service has been set, the user name and Department ID of the user who is currently logged in to the machine are printed.
The watermark "CONFIDENTIAL" is printed if a login service is not set.
7.
Set the background pattern and size → press [OK].
To print a pattern on the background of copy, select the background pattern from the Background Pattern drop-down list.
You can select [36.0 pt], [54.0 pt], or [72.0 pt] for the size of the text.
You can select [Magenta], [Cyan], or [Black] for the color of the text.
To change the print orientation for characters, press [Print Vertically].
To use white letters on a colored background, press [White Letters on Colored Background].
8.
Press [OK].
If you set the Printer Driver Secure Watermark mode, you can select whether to set the Secure Watermark function for each print job from printer drivers.
4.
Press [Printer Driver Secure Watermark].
If the Document Scan Lock mode is available for use, press [Printer Driver Watermark/Doc. Scan Lock].
5.
Press [Set].
If the Document Scan Lock mode is available for use, press [Driver Secure Watermark].
6.
To select Date:
Press [Watermark].
Select the type of watermark from the drop-down list → press [Next].
To select Date:
Press [Date].
7.
8.
Press [OK].
If [Printer Driver Secure Watermark] and [Forced Secure Watermark] are set for a printer at the same time, Forced Secure Watermark is given priority.
If you want to use the Secure Watermark function for each job from the printer driver, on the [Printing Preferences] dialog box, click the [Finishing] tab → [Advanced Settings] → select [On] for [Secure Printing Function of Devices]. For more information, see the on-line help for the printer driver.
