Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Device Management » Specifying Device Information Distribution Settings » Setting Automatic Distribution
0R9W-214
You can set to automatically deliver device information at a specified time. You can also select which information to deliver.
Press [Management Settings] → [Device Management] → [Device Information Distribution Settings].
Press [Set Auto Distribution] for <Transmitting Settings> → select [Everyday] or [Specify Days].
If you do not want to set automatic distribution, select [Off] → press [OK] → [OK].
If you select [Everyday]:
If you select [Specify Days]:
Press [Everyday].
Select a number ([1] to [5]).
Enter the start time using - (numeric keys) → press [Next].
You can store up to five different start times.
The time is displayed in 24-hour notation. Enter the time as a four digit number including zeros.
Examples:
7:05 a.m.
→0705
11:18 p.m.
→2318
If you make a mistake when entering the time, enter another four digit number.
Press [Specify Days].
Select a day of the week ([Sun] to [Sat]) → select a number ([1] to [5]).
You can store up to five different start times for each day of the week.
Examples:
7:05 a.m.
→0705
11:18 p.m.
→2318
4.
Specify each setting → press [Next].
Press [On] for an item to deliver that data.
If you press [On] for <Settings/Registration Value>, set <Network Settings>. You can press [Include] → [OK] to deliver the network settings.
5.
Select the destination → press [OK] → [OK].
When delivering device information, the following machines will not update their information:
Machines which are processing a send job
Machines importing or exporting data via the Remote UI
The client machine which is receiving device information from another host machine will not update the address book.
The client machine which is performing a print job will not update the printer settings.
Machines which could not receive device information because of a power failure or network trouble, will not receive updated information until the first automatic update after the machine recovers.
Device information is not delivered if the machine has entered the shutdown process, even if an automatic distribution time is set.
