Category Top
Preventing Unauthorized Access
Increasing Security
Network Security
Key Pair and Server Certificate Settings for Encrypted SSL Communication
Generating a Key Pair and Server Certificate
Registering a Key Pair File and Server Certificate File Installed from a Computer
Editing Key Pairs and Server Certificates
Registering/Editing a CA Certificate File
Verifying Certificate Validity Using Certificate Revocation List
Network Settings/Management when Using an Advanced Box
MEAP Settings
Using the SSL
Printing Installed Application Information
Preventing Information Leakage
Digital Signatures
Setting/Confirming a Key Pair and Device Certificate
Confirming a Key Pair and User Certificate
Checking a Device Signature/User Signature Certificate
Setting a Rights Management Server
Forced Secure Watermark/Document Scan Lock
Secure Watermark (Forced Secure Watermark/Printer Driver Secure Watermark)
Adjusting the Secure Watermark Contrast
Document Scan Lock Settings
Specifying the Document Scan Lock Operational Settings
Setting the Document Scan Lock Mode
Adjusting the TL Code
Copy Set Numbering Options
Accepting Only Encrypted Secure Printing
Restricting the Send Function
Setting the Address Book
Mail Box Settings
Specifying Settings for All Mail Boxes
Specifying the Mail Box Security Settings
Setting the Control Panel Display
Managing the Setting Information Registered in the Machine
Specifying Management Settings for the Memory
Completely Erasing Unnecessary Data from the Memory
Initializing All Data/Settings
TPM Settings
Device Management
Using the USB Port
Device Information Settings
Specifying Device Information Distribution Settings
Registering/Deleting/Printing Distribution Destinations
Setting the Receiving Machine
Setting Automatic Distribution
Setting Manual Distribution
Checking/Printing the Communication Log
Limiting Functions
Remote UI
Clearing the Message Board
Saving a Log of Key Operations
Starting the Setup Guide
Retrieving Audit Logs
IEEE 2600 Security Standard
Top » Security » Network Settings/Management when Using an Advanced Box
0R9W-1YK
You can register the Advanced Box (Network Place) of another imageRUNNER ADVANCE series machine which is opened with SMB or WebDAV as an external storage location and share the files in the Advanced Box.
Do not register something other than the Advanced Box of another imageRUNNER ADVANCE series machine which is opened externally, as this may cause the machine to malfunction.
Setting/Managing the Advanced Box of an External Reference (Network Place)
Press [Function Settings] → [Store/Access Files] → [Network Settings].
Press [Network Place Settings] → set the Network Place.
To register the Network Place:
To check the details of the Network Place:
To delete the Network Place:
Press [Register] → specify each setting.
[Name]:
Enter the name for external reference.
<Protocol:>:
Select [SMB] or [WebDAV] for the protocol.
For SMB: Set [Location] as follows.
Shared Space: \\host name or IP address\share
Personal Space: \\host name or IP address\users
For WebDAV: Set [Host Name] and [Folder Path] as follows.
Shared Space:
[Host Name]: http(s)://host name or IP address
[Folder Path]: /share
Personal Space:
[Folder Path]: /users
For instructions on entering characters, see "Entering Characters from the Touch Panel Display."
Press [OK].
Select the external network place to check → press [Details].
Press [OK].
Select the external network place to delete → press [Delete].
Press [Yes].
Press [Close].
Setting the Protocol for External Reference
You can select the protocol used when accessing the Advanced Box (Network Place) of another imageRUNNER ADVANCE series machine which is opened externally.
Press [Protocol for External Reference].
4.
Select [On] for the protocol to use → press [OK].
Press [Off] for <SMB> if you do not want to use SMB.
Press [Off] for <WebDAV> if you do not want to use WebDAV.
Confirming the SSL Server Certificate when Accessing the Network Place
You can confirm whether the SSL server certificate is valid when accessing the Advanced Box (Network Place) of another imageRUNNER ADVANCE series machine.
You can verify the validity of the certificate and reliability of the certificate chain, as well as confirm the CN (Common Name).
Press [Confirm SSL Certificate for Network Access].
4.
Press [On] → [OK].
Select [Off] if you do not want to confirm the SSL server certificate when accessing the Network Place.
To confirm the CN, press [CN] for <Add Items to Verify>.
If you do not verify the certificate, SSL communication is performed, even with an invalid certificate.
If a certificate error occurs when you try to access the Network Place, you cannot access the Network Place.
If a certificate error occurs when you try to access a folder/file in the Network Place, you cannot access the folder/file.
