[Printed Pages] indicates the number of printed surfaces. If you perform 2-sided printing on a sheet of paper, the number of the printed surfaces is two.
Register more than one Department IDs before enabling Department ID Management, which will have no effect with no Department ID registered.
(1)
[Register New Department...]
(Displayed only if you have logged on in Administrator Mode.)
The [Register New Department] page allows you to register department IDs.
Set the following items and then click [OK].
(2)
[Dept. ID]
(Clickable only if you have logged on in Administrator Mode.)
Clicking the department ID allows you to use the [Edit Department] page to change the password and clear the count by department. Set the following items and then click [OK].
(3)
[Settings...]
The [Department ID Management Settings] page allows you to enable/disable the department ID management function and specify whether to print jobs with unknown IDs.
(4)
[Printed Pages]
Displays the number of printed surfaces.
(5)
Delete the Selected Department
If you click [Delete] to the right of the Dept. ID to be deleted, the selected Dept. ID is deleted.
(6)
[Clear All Counts]
(Not displayed depending on the settings.)
Clears [Printed Pages] of all the departments.
