Table description
Bold values in the table indicate the default settings.
The setting items or setting values with "*" may not be displayed depending on the availability of the optional accessories and other settings.
About the icons
Setting Item
Setting Value
Setting
[Paper Source]
[Auto], [Drawer 1], [Drawer 2]*, [Drawer 3]*, [Multi-Purpose Tray]
Select the default paper source that is used when printing.
After a paper source is selected, the corresponding Paper Source indicator comes on.
[MP Tray Paper Size]
[A6], [
A5], [ A5R], [B5], [A4], [LTR], [LGL], [EXEC], [Mixed Sizes], [ Custom Size], [ Custom Size R], [Env. ISO-C5], [Env. Monarch], [Env. No.10], [Env. DL], [Index Card], [STMT], [FLSC], [16K] |
Specifies the size of the paper loaded in the multi-purpose tray.
[MP Tray Priority]
[Off], [On]
Specifies whether the printer should detect the paper source in order starting with the multi-purpose tray when [Paper Source] is set to [Auto].
[Drawer 1 Size]/[Drawer 2 Size]*/[Drawer 3 Size]*
[A6], [
A5], [ A5R], [B5], [A4], [LTR], [LGL], [EXEC], [Mixed Sizes], [ Custom Size], [ Custom Size R], [STMT], [FLSC], [16K] |
Specifies the size of the paper loaded in the paper drawer.
[Standard Paper Size]
[A6], [A5], [B5], [A4], [LTR], [LGL], [EXEC], [Env. ISO-C5], [Env. Monarch], [Env. No.10], [Env. DL], [Index Card], [STMT], [FLSC], [16K]
If you cannot specify the paper size or if you print from DOS, UNIX, or other operating system, specify the paper size in this item.
[Diff. Paper Tray]
[Off], [On]
Specifies whether to use the multi-purpose tray when the paper settings for the selected paper source are not the same as the paper settings in the received data.
[Auto Selection]
[Multi-Purpose Tray]: [Off], [On]
[Drawer 1]: [Off], [On]
[Drawer 2]*: [Off], [On]
[Drawer 3]*: [Off], [On]
Specifies the paper source to be automatically selected when [Paper Source] is set to [Auto].
If [On] is specified, the printer selects the paper source as the one to be automatically selected.
[Default Paper Type]
[Plain], [Plain L], [Heavy 1], [Heavy 2], [Transparency], [Envelope], [Labels]
If you cannot specify the paper type or if you print from DOS, UNIX, or other operating system, specify the paper type in this item.
[2-Sided Printing]
[Off], [On]
Specifies whether the printer should print on one side or both sides of the paper.
