e-ManualTopSite mapHelp
Chapter Top
Software That Can Be Used for Managing the Printer
Remote UI
Starting the Remote UI
Attention (Remote UI)
Enabling the Remote UI
Screen Layout of the Remote UI (Details on Each Setting Page)
Display/Change Message Board Messages and Support Links
FTP Client
NetSpot Device Installer
Managing Print Jobs
Attention (Job Manager)
Control Panel Setting
Attention (Control Panel Setting)
Setting Items
[Setup] Menu ([Control Menu] Options)
[Setup] Menu ([Paper Source] Options)
[Setup] Menu ([Network] Options)
[Setup] Menu ([Layout] Options)
[Setup] Menu ([Quality] Options)
[Setup] Menu ([Interface] Options)
[Setup] Menu ([User Maintenance] Options)
[Setup] Menu ([Print Mode] Options)
[Setup] Menu ([UFR II] Options)
[Setup] Menu ([PCL] Options)
[Setup] Menu ([Imaging] Options)
[Setup] Menu ([XPS] Options)
[Setup] Menu ([PDF] Options)
[Setup] Menu ([PS] Options)
[Setup] Menu ([MEAP Settings] Options)
[Setup] Menu ([Check Counter] Options)
[Utility Menu] Menu
[Job] Menu
[Reset] Menu
[Select Feeder] Menu
Checking the Number of the Printed Pages
Importing and Exporting Settings
Initializing the Settings
Initializing the [Setup] Menu Using the Printer's Control Panel
Checking the Printer Settings
Setting the Administrator Password
Specifying the Device Name or Administrator Information
Sleep Mode
Auto Shutdown
Printing Silently
Performing Printing Always with Silent Mode
Performing Printing with Silent Mode during a Designated Time
Specifying an ID for Each Department
Register/Update Software Function
Available Functions
Installing the System Options/MEAP Applications
Installing by Connecting This Printer to an Outside Network (Delivery)
Installing by Not Connecting This Printer to an Outside Network (Manual)
Downloading the Manuals and Related Software
Managing the Register/Update Software Function
Top » Managing the Printer » Software That Can Be Used for Managing the Printer » NetSpot Device Installer
08X4-0A0
NetSpot Device Installer is the Canon software included in the supplied CD-ROM.
<Features of NetSpot Device Installer>
You do not need to install NetSpot Device Installer.
You can start NetSpot Device Installer directly from the CD-ROM without installing it.
You can also install NetSpot Device Installer on a computer.
You can check the various printer statuses.
You can view the list of statuses of the Canon devices on a network easily.
Also, you can change the default network settings or basic protocol settings.
For details on other procedures for starting and using NetSpot Device Installer, see the following.
Starting method:
"Printer Driver Installation Guide"
For details on the procedure for viewing "Printer Driver Installation Guide", see "Installation."
Usage:
Help of NetSpot Device Installer
Help is displayed by clicking [Help] in the [Help] menu.
If Windows Firewall is enabled
Before starting NetSpot Device Installer, configure Windows Firewall to unblock NetSpot Device Installer.
For details on the configuration procedure, see the Readme file of NetSpot Device Installer.
About operating systems that NetSpot Device Installer supports
For details on the latest NetSpot Device Installer, see the Canon Web site (http://www.canon.com/).
