If you want to go back up the previous hierarchy or cancel a selected item
To go back up the previous hierarchy or cancel a selected item, press [
![]() ![]() ![]() Pressing [
![]() ![]() ![]() When the printer can be placed offline
The printer can switch back to the offline state when it is ready to print (when the
![]() About setting values
Depending on the item, some settings become effective after restarting the printer.
Setting priority
For details on the setting priority for when specifying the same item using a method other than the control panel as that specified using the control panel, see "Setting Priority (When Specifying the Same Item Using Multiple Methods)."
About items displayed in the display
Some items are added and displayed only when an optional accessory is installed, and you can select such items.
About the exclusive [Setup] menu
When the exclusive [Setup] menu is selected in the "Option" hierarchy, see the following about each option.
About [Initialize Menu]
[Initialize Menu] does not have a lower hierarchy than "Option."
For details on the procedure for the initialization, see "Initializing the [Setup] Menu Using the Printer's Control Panel." |
