Table description
Bold values in the table indicate the default settings.
Setting Item
Setting Value
Setting
[Auto Mode Selection]
[Auto Selection], [PCL], [PS], [PDF], [XPS]
Specifies the mode in which this printer operates when you print without using the printer driver for this printer.
If the print mode is not appropriate, such a printing problem as unreadable characters being printed may occur. Specify this item according to the job to be printed.
[Auto Select]
[PCL]: [Off], [On]
[PS]: [Off], [On]
[PDF]: [Off], [On]
[XPS]: [Off], [On]
Specifies the print mode to be automatically switched if [Auto Mode Selection] is set to [Auto Selection].
If [On] is specified, the mode is to be automatically switched to.
[Mode Priority]
[None], [PCL], [PS], [PDF], [XPS]
You can specify [Mode Priority] to be switched to by priority for when [Auto Mode Selection] is set to [Auto Selection] and this printer cannot identify the control command of the data.
If you specify [None], the printer does not specify the mode priority. If this printer cannot identify the control command of the data, it determines the mode automatically.
