e-ManualTopSite mapHelp
Chapter Top
Software That Can Be Used for Managing the Printer
Remote UI
Starting the Remote UI
Attention (Remote UI)
Enabling the Remote UI
Screen Layout of the Remote UI (Details on Each Setting Page)
Display/Change Message Board Messages and Support Links
FTP Client
NetSpot Device Installer
Managing Print Jobs
Attention (Job Manager)
Control Panel Setting
Attention (Control Panel Setting)
Setting Items
[Setup] Menu ([Control Menu] Options)
[Setup] Menu ([Paper Source] Options)
[Setup] Menu ([Network] Options)
[Setup] Menu ([Layout] Options)
[Setup] Menu ([Quality] Options)
[Setup] Menu ([Interface] Options)
[Setup] Menu ([User Maintenance] Options)
[Setup] Menu ([Print Mode] Options)
[Setup] Menu ([UFR II] Options)
[Setup] Menu ([PCL] Options)
[Setup] Menu ([Imaging] Options)
[Setup] Menu ([XPS] Options)
[Setup] Menu ([PDF] Options)
[Setup] Menu ([PS] Options)
[Setup] Menu ([MEAP Settings] Options)
[Setup] Menu ([Check Counter] Options)
[Utility Menu] Menu
[Job] Menu
[Reset] Menu
[Select Feeder] Menu
Checking the Number of the Printed Pages
Importing and Exporting Settings
Initializing the Settings
Initializing the [Setup] Menu Using the Printer's Control Panel
Checking the Printer Settings
Setting the Administrator Password
Specifying the Device Name or Administrator Information
Sleep Mode
Auto Shutdown
Printing Silently
Performing Printing Always with Silent Mode
Performing Printing with Silent Mode during a Designated Time
Specifying an ID for Each Department
Register/Update Software Function
Available Functions
Installing the System Options/MEAP Applications
Installing by Connecting This Printer to an Outside Network (Delivery)
Installing by Not Connecting This Printer to an Outside Network (Manual)
Downloading the Manuals and Related Software
Managing the Register/Update Software Function
Top » Managing the Printer » Specifying the Device Name or Administrator Information
08X4-0C8
This section describes the procedure for specifying the settings using the Remote UI.
In the Remote UI, you can specify the settings by accessing the printer from a Web browser via a network.
When specifying the settings using software other than the Remote UI
You can also specify the settings using the following software.
You can specify the settings by accessing the FTP server of the printer using Command Prompt.
You can specify the settings using the Canon software, NetSpot Device Installer, in the supplied CD-ROM.
1
Start the Remote UI, and then log in as Administrator.
2
Select [Security] under [Management Settings] in the [Settings/Registration] menu.
3
Click [Management Settings].
4
Click [Edit...] under [Management Settings].
5
Enter the current password in [Current System Manager Password].
6
Specify the device name or administrator information.
(1)
Specify the settings for each option as needed.
(2)
Click [OK].
[System Manager]
Enter the name of the system manager.
[Contact Information]
Enter the system manager's contact information.
[E-Mail Address]
Enter the system manager's email address.
[System Manager Comment]
Enter the system manager's comments.
[Device Name]
Enter the name of the printer.
[Location]
Enter the location of the printer.
