Before specifying the setting, see "Attention (Control Panel Setting)."
Operation Procedure
Key Operation
1
Place the printer offline.
Press [
] ( Online). |
When the printer is online, the [Setup] menu can be displayed, however, the [User Maintenance] options cannot be specified.
2
Display the [Setup] menu.
Press [
] ( Settings). |
The [Setup] menu is displayed.
3
Select the option.
When the [Paper Source] options are selected
Press [
] or [ ]. |
The target option is displayed.
4
Display the item.
Press [OK].
The selected item is displayed.
5
Select the item.
When [Drawer 1 Size] is selected
Press [
] or [ ]. |
The target item is displayed.
6
Select the item.
Press [OK].
The selected setting value is displayed.
7
Select the setting value.
When [B5] is selected
Press [
] or [ ]. |
The target setting value is displayed.
8
Determine the selected setting value.
Press [OK].
The target setting value is specified.
The setting completion screen is displayed for 3 seconds. You can change the display time for the screen using [Set. Comp. Notify] in the [Setup] menu. |
9
Go out of the setting menu.
Press [
] ( Online). |
: You can enter the menu
: You cannot enter the menu
When the printer is ready to print *1
When an error is occurring *2
When the printer is offline
[Setup] Menu
*3 |
[Select Feeder] Menu
[Reset] Menu
*4 |
[Job] Menu
[Utility Menu] Menu
Application menu
*1
The printer is ready to print when the
Ready indicator is on. |
*2
An error is occurring in the printer when the
Message indicator is on. |
*3
The [User Maintenance] options cannot be specified.
*4
You cannot perform [Form Feed].
