e-ManualTopSite mapHelp
Chapter Top
Software That Can Be Used for Managing the Printer
Remote UI
Starting the Remote UI
Attention (Remote UI)
Enabling the Remote UI
Screen Layout of the Remote UI (Details on Each Setting Page)
Display/Change Message Board Messages and Support Links
FTP Client
NetSpot Device Installer
Managing Print Jobs
Attention (Job Manager)
Control Panel Setting
Attention (Control Panel Setting)
Setting Items
[Setup] Menu ([Control Menu] Options)
[Setup] Menu ([Paper Source] Options)
[Setup] Menu ([Network] Options)
[Setup] Menu ([Layout] Options)
[Setup] Menu ([Quality] Options)
[Setup] Menu ([Interface] Options)
[Setup] Menu ([User Maintenance] Options)
[Setup] Menu ([Print Mode] Options)
[Setup] Menu ([UFR II] Options)
[Setup] Menu ([PCL] Options)
[Setup] Menu ([Imaging] Options)
[Setup] Menu ([XPS] Options)
[Setup] Menu ([PDF] Options)
[Setup] Menu ([PS] Options)
[Setup] Menu ([MEAP Settings] Options)
[Setup] Menu ([Check Counter] Options)
[Utility Menu] Menu
[Job] Menu
[Reset] Menu
[Select Feeder] Menu
Checking the Number of the Printed Pages
Importing and Exporting Settings
Initializing the Settings
Initializing the [Setup] Menu Using the Printer's Control Panel
Checking the Printer Settings
Setting the Administrator Password
Specifying the Device Name or Administrator Information
Sleep Mode
Auto Shutdown
Printing Silently
Performing Printing Always with Silent Mode
Performing Printing with Silent Mode during a Designated Time
Specifying an ID for Each Department
Register/Update Software Function
Available Functions
Installing the System Options/MEAP Applications
Installing by Connecting This Printer to an Outside Network (Delivery)
Installing by Not Connecting This Printer to an Outside Network (Manual)
Downloading the Manuals and Related Software
Managing the Register/Update Software Function
Top » Managing the Printer » Checking the Printer Settings
08X4-0C6
You can check the printer status, network settings, and so on by printing Configuration Page or Network Status Print.
Configuration Page or Network Status Print is designed to be printed on Letter paper. Be sure to use Letter paper.
You can also check the network settings and so on using the following software.
1
Load Letter size paper in the multi-purpose tray or paper drawer.
2
Make sure that the printer is online (the Online indicator is on).
If the Online indicator is off, press [  ] (Online).
3
Press [  ] (Utility).
4
Select [Configuration Page] or [Network Status Print] using [  ] or [  ], and then press [OK].
Prints the list of currently available functions for the printer and setting values of the menus, and so on.
Prints the TCP/IP settings including the IP address and information including security settings.
5
Select [Yes] using [  ], and then press [OK] to print Status Print.
